Author Topic: Freeze plugs..???  (Read 2012 times)
Offline go-fish
Re: Freeze plugs..???
« Reply #15 on: May 13, 2007 - 06:20:50 PM »
Yep, I went out myself today and looked at my block. Two of them on the back. Why would they put them back there? Geez!
Offline PlumCraZRT
« Reply #16 on: May 13, 2007 - 11:18:49 PM »
Probably because they dont want your block to crack when it freezes... DUH!  :bigsmile:
mmmmm.... Mopar.... *drool*
Offline 360 'CUDA
« Reply #17 on: May 14, 2007 - 12:09:32 AM »
I'm not a foundary engineer but it seems to me that freeze plug holes are not just there to protect the block from freezing.  I think they are part of the casting process and the sand runs out of them when the block cools down after casting.  It makes sense when you think of all the blocks and heads Mopar has to make in one day they have to have lots of holes to let the sand out quickly
Offline go-fish
« Reply #18 on: May 14, 2007 - 04:17:33 AM »
I would figure all the other freeze plugs on the sides and in the heads would do that. Double Duh! :bigsmile: :bigsmile:
Offline chrisII
« Reply #19 on: May 14, 2007 - 05:28:41 AM »
There are two 1 5/8 inch freeze plugs on the back of the block,I keep them in stock at the shop because it seems like they are the number ones to go bad because of lack of circulation. Best time to change them is when the tranny is out. :grinyes:
i find it funny that you say that, ive had about a hundred small blocks, never had an issue with those plugs..had one blow out of the back of a head once (messy). Ive changed a bunch of the side ones that corroded out, but being the rears are straight up and down they dont collect sedement like the ones on the sides do, creating more rust. also they arent exposed to the elements on the outside as the side ones are (road salt rain water ect). ive actually only had one front block plug leak, cant remember its location but its near the fuel pump. had to pull the alt to get at that one, it was in a 2wd pickup an they get alot of crud on the front of the engine when people leave those rubber flaps out.
Offline tactransman
« Reply #20 on: May 14, 2007 - 06:42:25 AM »
When the rear ones are leaking and removed,the sediment is always piled half way up the plug on the inside. I don't think there is much coolant circulation back there. :dunno:
Terry-tactransman
Union, Mo.
