Heater/ Ac Blower problems...
Author Topic: Heater/ Ac Blower problems...  (Read 870 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: May 13, 2007 - 01:37:03 PM »
I can't get the heater blower to work with the blower switch. I check the blower motor directly to the battery and it works fine. I replaced the blower switch and the blower resistor. And I've check if the wire are correctly hooked up. As far as I can tell they are hooked up right. (see picture of the back side of the ac/ heater switch) How can I check were I loose the power to find the wire error?
Where do I start?
« Last Edit: May 13, 2007 - 01:41:50 PM by widing'cuda »
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Re: Heater/ Ac Blower problems...
« Reply #1 on: May 13, 2007 - 04:50:57 PM »
the red plug should bring power in &  send it out test which wire is power & short it to the other wires , the switch may be the problem
Offline widing'cuda
« Reply #2 on: May 14, 2007 - 10:50:02 AM »
Ok, I'll test it. Are the blue and light green wires hooked up right?
Offline widing'cuda
« Reply #3 on: May 14, 2007 - 03:10:39 PM »
Found the error. It's the AC/ vacuum switch panel that's broken/busted.
Offline widing'cuda
« Reply #4 on: May 15, 2007 - 02:22:45 PM »
Are my blue and light green wire hooked up right?
