I got my G3 Hemi running today on the stand.
This is what was needed so far to get it setup like mine.
A running 04 to 08 Hemi with a car cover or preferably out of a car. The exhaust manifolds I show are from an 07 Chrysler 300.
Modify the Throttle Body, like I show in the posts above.
The Milodon conversion pan #31000, around $255. I cut an original truck pickup down and welded it to fit the new sump.
The 45 degree oil filter adapter, used $45.
Used an oil filter for 10 Challenger 3.5 V6 with this adapter.
Conversion Flywheel from Mcleod, new shipped price was $300.
Dodge Stratus A/C compressor, junk yard with a 1yr warranty, $39, Had to make a mount to attch it to the block at 3 points. Factory Compressor did not fit the TTI, E-body conversion mounts.
MSD 6013 to control the timing and fire the coils. USED $450, came with wiring harness, but for new coils.
Bought a set of new style used coils on Facebook swap page. $??
Bought a set of NEW plastic valve covers to mount the NEW style used coils. Ebay $?
EZ-EFI control unit $189 Ebay.
EZ-EFI handheld, $59 Ebay.
Bought a used engine harness to chop off the injector plugs and TBI plug, to use on my EZ-EFI harness. Facebook $??
The rest of the EZ-Harness I made up from an older Holley 950 EFI harness so that I can test with the Commander 950 ECU if I choose to.
Sensors for the EZ are common AIT, CLT, MAP from 90s GM cars in junk yards. O2 is from an 05 Nissan Altima 2.5.
Fuel pump off of a 89-92 E150 ford van, Usually mounted to the frame under the driver's seat, in the junk yards.
I'm using a K-frame from a 74 E-body with the factory power steering box. I had to remove some of the driver's side PS Box/motor mount pedestal to fit the A/C compressor. (not much)
If I remember anything else, I'll add it later.
MY setup and first startup is on my YouTube channel here:
https://youtu.be/I8n8rqEwIsc
