Author Topic: how to date code 4 speed  (Read 638 times)
Offline raj
« on: May 15, 2007 - 06:32:20 PM »
 :clueless: I have a extra 4 speed from an A body and i need a set of syncro drum keys for a 70-74 e-b body. My understanding is the drum keys. vary from 64 to 67
68-69 and 70 to 74 is another size. so i would like to know what vintage the A body is whith out haveing to tear it down. Is there some way to date code the trany. :cheers:Thanks
Re: how to date code 4 speed
« Reply #1 on: May 15, 2007 - 11:14:12 PM »
there is a date code stamped ont he right side of the trans
 but I would still pull the side cover to be sure that nothing has been swapped internally
 Also Passon will sell you new sets of keys for the 70-74 , they use the wider key used into the late 80s
Offline raj
« Reply #2 on: May 16, 2007 - 10:02:21 AM »
 :burnout: Thanks chryco i will check it to night. I live in B.C. so it takes a while to get the parts from passion .
« Reply #3 on: May 16, 2007 - 03:44:49 PM »
I believe Passon has a dealer for Canada set up in BC
