Author Topic: Follow up:No oil in rocker arms  (Read 626 times)
Offline cmesa
« on: May 16, 2007 - 05:10:30 AM »
I loosened the bolts that hold the rocker arm rod (5 bolts) one at a time. I noticed that oil comes out of the last three bolts holes. I also noticed that the third lifter on the affected side is working but not loose ( does not slide out when I take the rod out). I am going to try pouring mystery oil to see if the holes are clogged. Is there anything else that I can try.
Thank You
Re: Follow up:No oil in rocker arms
« Reply #1 on: May 16, 2007 - 05:15:39 AM »
if i understand correctly yo umay have eaten a lobe on the cam
