CP- thanks, Ill investigate the promax options
KS_
Pics of the way that the carb and throttle linkage hook up is what I need a pic of most. Driver and passenger side of the carbs basically.
Moper:
Six Pack is going on my 440 in the Challenger,
replacing a StreetDominator and a 800cfm Holley spreadbore DP. Keisler 5 speed trans, 3.23 gears, 25.5" tall tires. Having some 915 heads redone right now with 2.14 intake, 1.81 exhst, gasket matched and first 250$ of porting, hardened seats etc. Cam is an Engle K54/56split duration with 112* HP manifolds, dual 832 springs. and 2.5" h-pipe TTI exhaust. With new heads I am anticipating around 9.0-1 compression, static. Car currently passes emissions. MSD6al with rev control at 5000. FBO distributor. Car is a CA emissions car from the factory.
16000 miles on an original Cast crank 440 block, pump gas of course with low compression
Also swapping in a sanden A/C compressor to replace the old big A/C and to fit with the 6 pack.
no drag racing at a track. Just a street car. Now with change in AZ law, I dont have to pass emissions testing anymore, but I do get annoyed with a car that runs rich.
might rebuild the short block in a couple years at which time I would likely deck the block and change the pistons to get me up to around 9.7 compression, static. but the top end Im doing today would likely just re-bolt on.
Thanks Everyone!
