Author Topic: I want to see oil pan baffles! How do YOU do them?  (Read 2028 times)
Offline wjaholic
« on: May 16, 2007 - 12:47:31 PM »
I am working on rebuilding a 440, pretty much stock nothing special really. I am going to be using the 699 pan. I was really surpised when I pulled the pan off the engine and didn't find any baffles in it. Now I am trying to do some research on baffles and see what works and what doesn't.
If you have any comments, suggestions, tips or tricks, I would love to hear about them. As always if you have ANY pics of youre baffles (custom or original) in just about any mopar pan I would love to see them as well.
Thanks!
Offline Super Blue 72
    • Phil's Super Blue '72
Re: I want to see oil pan baffles! How do YOU do them?
« Reply #1 on: May 16, 2007 - 02:36:50 PM »
  :popcorn: :clueless:
I'm curious about these baffles.  Do you mean windage trays so the oil doesn't splash around?
Offline matt63
« Reply #2 on: May 16, 2007 - 02:55:08 PM »
I don't have a pic but my buddy welded a small horizontal baffle in the bottom section of the tray.  You just have to make sure it doesn't hit the pickup!  I would look at a Milodon tray and copy their design.
Matt in Edmonton
'68 Valiant
« Reply #3 on: May 16, 2007 - 03:55:47 PM »
I bring the rear baffle forward as far as possible & angled slightly down into the sump & leave some small openings in the corner of the pan , the fromnt is done similarly but is less important , it just traps oil during braking when you are off the throttle...... generally
Offline wjaholic
« Reply #4 on: May 16, 2007 - 06:39:15 PM »
I plan on using the mopar performance windage tray. Its nothing special, my brother has been running one on his 383 for years. No problems yet. I think I am going to aim for a baffle that goes all the way around the "sump" of the pan. Very simialar to the one shown on the 440source page. Here... http://www.440source.com/oilpans.htm  it is the second one down - the chrome one. Let me know what you guys think.
« Reply #5 on: May 16, 2007 - 07:44:37 PM »
Same idea , unless you are cornering extremely hard the side baffles will not make any difference
 The windage tray works great too , the other option is a crank scraper also good for a few extra HP
Offline PlumCraZRT
« Reply #6 on: May 16, 2007 - 09:05:37 PM »
I've read that the crank scraper has to be done custom, cause if it isn't within like an 1/8 of an inch from the crank it doesn't do any good.  Basically the closer the better.
mmmmm.... Mopar.... *drool*
Offline matt63
« Reply #7 on: May 16, 2007 - 09:09:24 PM »
I think the baffles and windage tray are two separate issues.  The baffle prevents starvation of the pump and the windage tray keeps oil off of the crank throws.
Matt in Edmonton
'68 Valiant
« Reply #8 on: May 16, 2007 - 11:58:30 PM »
-Baffles keep the oil in the sump preventing starvation from uncovering the pick up
-Windage trays cut some oil off the crank & also pevent the windage from lifting the oil up in the sump & uncovering the pick up
-Scrapers remove Far more oil from a crank than a windage tray
 for max results use all 3
« Reply #9 on: May 17, 2007 - 06:23:45 AM »
 :biggrin:  Ahhhh....thanks guys, I am enlightened now!  :grinyes:
Offline aussie-e-body
« Reply #10 on: May 17, 2007 - 08:45:17 AM »
went out and took a shot of mine.super commando im told.i reckon you could make and fit these in a couple of beers. :thumbsup:
i want it all-i want it yesterday-and i want it for nothing
Offline Dragula
« Reply #11 on: May 19, 2007 - 12:25:04 PM »
Pic is shown without windage tray and swinging pick-up bolted in. It has a swinging pick-up at the rear behind the one-way trap door baffel, and crank scrapper. Also at the front, I had a 2" lip welded in to keep oil from splashing back up into the tray on hard braking for any that didn't get trapped in the rear of the pan on accel.
« Last Edit: May 19, 2007 - 12:27:56 PM by dragula »
Offline wjaholic
« Reply #12 on: May 22, 2007 - 03:47:21 PM »
Thanks for all the info and pics!!! I appreciate it all!
