Author Topic: need some advice??  (Read 655 times)
Offline cudachuck
need some advice??
« on: May 19, 2007 - 01:03:48 PM »
i'm cloning a 1970 hemi cuda convertible and i need to know what rear would you suggest using if i can't find a real dana 60. who makes the best repo dana 60 (that looks the closest to the original)and what gears should i run thanks
Offline Carlwalski
Re: need some advice??
« Reply #1 on: May 19, 2007 - 02:34:03 PM »
Not sure "who's the best" as like many parts there are several who do good work.
Moser, Dr-Diff are a couple that come to mind, others may help you on that.
Gears? What transmission are you running and do you do lots of highway driving? 3.55 or 3.73 are a nice gear, if you like good response 4.10 perhaps, but if you drive on the freeway heaps 4.10s won't be so good.
Lots of variables.........
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline cudachuck
« Reply #2 on: May 19, 2007 - 03:08:16 PM »
well which one looks the most like the dana 60 thanks
Offline Carlwalski
« Reply #3 on: May 19, 2007 - 05:56:15 PM »
Dr-Diff uses the best parts from different brands and makes them look stock or if preferred dressed up.
