Author Topic: cuda problem??  (Read 1241 times)
Offline cudachuck
cuda problem??
« on: May 19, 2007 - 01:21:57 PM »
i have a 1970 cuda convert. and the pass. rear bumper sits about a inch lower the the drive side it was origionally a 318 car but now has a 383 and i haven't changed the leaf springs yet. do you think that is it or should i try something else thanks
Offline Carlwalski
Re: cuda problem??
« Reply #1 on: May 19, 2007 - 02:35:04 PM »
Just sounds like the lines and gaps were not placed properly.  :dunno:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: cuda problem??
« Reply #2 on: May 19, 2007 - 02:51:00 PM »
Probably leaf springs are worn out. The other thing is the tosion bars may need adjusted due to the weight of the big block. Assuming you kept the SB torsion bars in the car.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline SilverChally
Re: cuda problem??
« Reply #3 on: May 19, 2007 - 10:23:02 PM »
Measure other areas, like rear bottom of the rocker, frame, and such.  When I built my first leaf spring mopar, I put the rear springs in on the wrong sides, so mine sat the same way because of the extra leaf for a 4 speed :roflsmiley:
70 challenger project
68 satellite
Offline Carlwalski
Re: cuda problem??
« Reply #4 on: May 20, 2007 - 12:48:14 AM »
Is he talking about the gap or the actual car is sitting lower on the LH side?
Gotta love vague newb questions............. :clapping: :grinno:
Offline cudachuck
Re: cuda problem??
« Reply #5 on: May 20, 2007 - 08:41:58 AM »
i measured from the ground to the of the rear tube on the driver side and pass. and both the same. than the bumper to ground and the pass is about a inch lower. i haven't change anything since i got the car. i'm going to change the leaf springs were would you suggest to get them i've heard bad things about mopar performance?
Re: cuda problem??
« Reply #6 on: May 20, 2007 - 08:47:53 AM »
Many have used & recomend Espo/Springs n Things, Do a search here & you sill see several topics discussing them.
Offline tactransman
Re: cuda problem??
« Reply #7 on: May 21, 2007 - 08:33:14 AM »
How about some pics? :picture:
Terry-tactransman
Union, Mo.
Offline IMNCARN82
  • LeDZeP
Re: cuda problem??
« Reply #8 on: May 22, 2007 - 06:02:27 AM »
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline Super Blue 72
    • Phil's Super Blue '72
Re: cuda problem??
« Reply #9 on: May 22, 2007 - 06:59:31 AM »
Sounds like the body of the car is level but just the bumper is off by an inch?  :dunno:
Offline 360 'CUDA
Re: cuda problem??
« Reply #10 on: May 22, 2007 - 09:26:42 AM »
Welcome Chuck   :wave:
It does sound like a suspension problem but it's hard to say what is causing it without an inspection
Here is a Avatar pic you can use to downsize yours
