Author Topic: my cuda sits lower on one side  (Read 949 times)
Offline cudachuck
« on: May 19, 2007 - 02:16:37 PM »
when looking at the back of the car the pass side hang about a inch lower then the driver side what wrong???
Offline bordin34
Re: my cuda sits lower on one side
« Reply #1 on: May 19, 2007 - 02:55:33 PM »
Im not sure, but I think that one side had an extra leaf on the leaf springs.
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
« Reply #2 on: May 19, 2007 - 04:14:57 PM »
either increase the pressure on the low side torsion bar or reduce pressure on the opposite T bar
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #3 on: May 19, 2007 - 04:39:56 PM »
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
nivvy
« Reply #4 on: May 19, 2007 - 06:04:48 PM »
I had the same problem... I was using SS springs and moved the battery to the trunk on the passengers side. also if your in your garage it may be tapered for drain runoff in the middle of the garage making it look worse than it is...
« Reply #5 on: May 20, 2007 - 08:58:36 AM »
make sure none of the leafs are broken
