Author Topic: 72-74 Challenger full quarter fitment and quality review  (Read 1314 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: May 19, 2007 - 02:24:40 PM »
Just "dropped" the Driver's side  quarter on my car -
Heres how it went:
< http://www.pbase.com/dmz73/image/72322711 >
< http://www.pbase.com/dmz73/image/78132413 >
< http://www.pbase.com/dmz73/image/78949742 >
The only see two issues that will require slight modification. I know, it should be perfect, but.....
1. the furthest rear  flange to the tail panel  - just below the body line where it drop into the bumper. I think this area will require some gentle "persuasion"
2. in the trough area  adjacent to the dutchman- (otherwise known as the decklid filler panel ) the angle of flat on the flange that Goodmark  gives you is just a little too much, so it needs to be trimmed slightly.
Hope this helps.
Dan
Offline 360 'CUDA
Re: 72-74 Challenger full quarter fitment and quality review
« Reply #1 on: May 19, 2007 - 02:37:35 PM »
SO much better then when we first saw it  :2thumbs:
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #2 on: May 19, 2007 - 02:45:25 PM »
 The only thing else different is the drain hole on the bottom is too square and big. Other than that they fit good. I even modified a set to fit a conv. Took some time and planning but saved a real limegreen RT conv.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline DMZ73
« Reply #3 on: May 19, 2007 - 04:00:27 PM »
Here is a pic or two...
< http://www.pbase.com/dmz73/image/79028096 >
< http://www.pbase.com/dmz73/image/79028095 >
< http://www.pbase.com/dmz73/image/79028093 >
Thanks for the positive reinforcement. :thumbsup: It does look leaps and bounds from what I started with. NOw, if my wife could only share  the enthusiasm... :clapping:
more to come....
Dan
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #4 on: May 19, 2007 - 04:07:19 PM »
Don't worry, the wives usually come around when it's done and they can drive it. Until then it's it's just "some junk car" that's costing alot of money. :smilielol:
Offline SilverChally
« Reply #5 on: May 20, 2007 - 10:15:05 AM »
I used the 70-1 style and the problems I had were: the ds drip rail area that meets the trunk lid was sorta curved, not much, but enough it needed filled in to get the gap right.  Where they meet up with the roof seam, they seem too low, and need built up some.  I couldnt really move the quarter out or Id have other issues.  They have some creasing on the bends and such, but overall are straight and make a much cleaner fit than the patch style.
70 challenger project
68 satellite
Offline MyMopar
« Reply #6 on: May 24, 2007 - 11:43:31 AM »
Do the holes line up for the trim clips here or will you have to fill and redrill?
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
« Reply #7 on: May 24, 2007 - 01:18:28 PM »
The ds was about right on for the 70 ones, ps was off!  The clips slide correct?  Id drill with the goodmark holes and slide the clips where needed instead of filling and drilling new holes.
68 satellite
Offline DMZ73
« Reply #8 on: May 28, 2007 - 07:35:54 AM »
No, unfortunately no one is that accurate. The trim holes absolutely  do not allign. I see one is spot on, but the others are 1/2" or more away from being on target. No biggie. I did not expect anything THAT good.
Wat are you referring to about "The clips slide correct" Are you referring to the flanges to hold the J-tabs for securing the rear valence panel?
I have not yet gotten that far, but I will let you know as I get further into the final allignment. Right now it is clamped on the car just so that I do not snag myself on the way out to my daily driver. I need a few hours or more to get her on for good. I have a little bit of prep work to do before she goes on for good.
Dan
Offline dougs bs23
« Reply #9 on: May 29, 2007 - 05:33:46 AM »
 :roflsmiley: :roflsmiley: so true,,, i hear that almost daily
