Author Topic: Nuetral safety & Back up switch  (Read 1066 times)
JiminNJ
« on: May 19, 2007 - 06:29:27 PM »
My 70 Challenger back up light stays on in any Trans possition, replaced the switch in the trans, but the new one made the starter keep running, put old switch back in, What could be the problem?   Jiminnj
Offline GoodysGotaCuda
Re: Nuetral safety & Back up switch
« Reply #1 on: May 19, 2007 - 06:32:46 PM »
Okay so your reverse lights are always on with the old and the new neutral safety switch, correct?
You replaced the NSS and it instantly started cranking the engine?
1976 Dodge Warlock
Wheel & Tire Specs:Link
JiminNJ
« Reply #2 on: May 20, 2007 - 11:46:44 AM »
The back up light stayed on but the starter  wouldn't stop with the new nss.
the old nss swicht just keep the back up on, starter was normal.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: May 20, 2007 - 12:18:47 PM »
You have more than one problem. The only way the starter can stay in the run position is either, your relay is sticking or the ignition switch is bad or both.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: May 20, 2007 - 12:33:20 PM »
My car had the lights stuck on before, I think it was a loose connection on the NSS.  The starter staying on is odd though.
Tom :cheers:
Tom
« Reply #5 on: May 20, 2007 - 03:53:31 PM »
if the Strater realy has constant power for some reason & the NSS stays grounded the starter will not stop , you could have the wrong valve body in the trans for the Nss you installed causing it to stay grounded
JiminNJ
« Reply #6 on: May 21, 2007 - 01:59:01 PM »
Can anyone tell me the Dodge part Number for the NSS on the 727 Trans, for 70 challenger. I just restored the inside panels, Dash,gauges,switches,stainless trim, wiper motor,and the bumber bumber, I'd hate this switch  to stop progress. Thanks for replies.
« Reply #7 on: May 21, 2007 - 09:19:44 PM »
it will be a 3 prong switch
 if the valve body is from an eralier the 68 year it will not work correctly though
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #8 on: May 22, 2007 - 08:54:17 AM »
the switch is available # 2932820 was used from 69-84 , I have the switch and a new repair end in stock.
David
Mopar Dave
73 F8 Challenger
1990 XJ - sold
JiminNJ
« Reply #9 on: June 20, 2007 - 10:29:54 AM »
Thanks to all that replyed.  I replaced the NSS and found a complete wire harness including the worn out bulk head plug for the switch. The other problem was in the relay, someone wired the ignition into the wrong post so it didn't need the NSS and it started in any gear. ( How ofton do ya try and start a car in drive? ) The car runs great now, If I could only get my headlight bezels back ( 6 months) from a Chrome outfit my restoration would be complete,    Thanks  Jim
Offline 422STROKER
« Reply #10 on: June 20, 2007 - 02:14:08 PM »
Glad to hear you worked it out.
Tom :2thumbs:
Tom
