Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Light valve springs for break-in?
« previous
next »
Print
Pages: [
1
Author
Topic: Light valve springs for break-in? (Read 957 times)
torredcuda
Sr. Resident
Epping NH joined 11/23/03
on:
May 20, 2007 - 05:07:29 AM »
Getting close to a completed engine and am considering installing light valve springs just for break-in on the new solid cam,do I need to or just use the ones for the cam?I`l be using the Rotella T and Comp cams oil additive per there tech sheet but figure the lighter springs will help too?
Logged
Jeff
72 Barracuda 340/4spd Torred
70 roadrunner 383/auto In-Violet
70 Duster 360/auto drag car (Petty Blue soon)
04 Ram 2500 5.7 Hemi
GoodysGotaCuda
Sr. Resident
Re: Light valve springs for break-in?
Reply #1 on:
May 20, 2007 - 06:42:10 AM »
I personally would if i had softer springs laying around. I much rather do all i could to avoid a ate cam issue, so the extra time to swap them would be worth it to me.
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
May 20, 2007 - 09:01:10 AM »
I agree , while it is a pain to swap springs on an engine in car I feel it iiis worth doing , changing the cam out is more of a pain & more costly
Logged
torredcuda
Sr. Resident
Reply #3 on:
May 20, 2007 - 10:03:35 AM »
Since the rebiuld is due to a wiped cam I want to avoid going thru it again!Any springs you would recommend to use-stock 318 type or???
Logged
Jeff
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
May 20, 2007 - 03:58:43 PM »
if there are a dual spring I would just use the outer spring , if there are a single spring it should live without a lighter spring , Make sure the cam is well coated in break in lube & use either Mopar Oil conditioner or Gm EOS with the oil when you break it in
Logged
drag-n-cuda
Jr. Member
Reply #5 on:
May 20, 2007 - 07:14:47 PM »
torredcuda,
What are your cam specs, spring pressures? Just asking, because it might not be necessary.
my $.02,
drag-n
Logged
moper
Resident
Reply #6 on:
May 20, 2007 - 07:24:53 PM »
I agree with CP and drag-n..basically, single springs should be fine for break in. Duals loose the inners. I use 340lbs over the nose as my limit. Above that, you should arrange to use a lighter spring, or remove the inner.
Logged
ntstlgl1970
Resident
T a c o c a t
Reply #7 on:
May 23, 2007 - 11:13:33 AM »
Make sure the lifters are rotating too
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
