Author Topic: Is sb bypass hose long enough?  (Read 629 times)
Offline drag-n-cuda
« on: May 20, 2007 - 06:58:32 PM »
Does anyone know if you can use a stock bypass hose on a sb Victor intake? The bypass nipple is a bit higher, because of the raised thermostat housing location and if I need something else, I could use a p/n or application.
Thanks,
drag-n
Offline go-fish
Re: Is sb bypass hose long enough?
« Reply #1 on: May 20, 2007 - 07:56:00 PM »
I don't have a stock intake but I have a small block Super Victor here. Would a picture help. I just had it powder coated and it's laying around. My wife made me take it off of the cofee table.
« Reply #2 on: May 21, 2007 - 12:51:33 AM »
it should be fine , some of the aftermarket hoses are made a bit longer as well
Offline drag-n-cuda
« Reply #3 on: May 22, 2007 - 05:20:52 PM »
go-fish,
     I should be able to bolt up the intake tomorrow to confirm.  Engine's at the machine shop and the intake is in the truck.  I was just trying to go prepared.  Other guys using the victor 340, plug the bypass and drill 3 or so small holes in the thermostat flange.  Just trying to get all options, so I can make the best decision for myself.
Thanks,
catfish
Offline chrisII
« Reply #4 on: May 22, 2007 - 07:35:35 PM »
the ones ive bought were a bit long and had to be trimmed down for stock use. you shuld be fine
