Author Topic: numbers decode on side of 4 speed  (Read 1377 times)
« on: May 21, 2007 - 09:03:00 AM »
What are these numbers?  And does it help tell me the ratio?
The pad reads   ob433365   is this a 70?   the rest reads  C  99129   H
PP 8333149      0004
I put an adapter ring on it to run a big block bellhousing.  I was told it was out of a cuda/barracuda, but don't know the year. My car is a 70 of course and it was a 318 / 4 speed from the factory, missing engine and transmission.  Now I have a 440-6 and this trans.
Anyone know what year this is and maybe the gear ratio?    thanks  ALAN
Re: numbers decode on side of 4 speed
« Reply #1 on: May 21, 2007 - 08:16:02 PM »
Ok, I did a search for old posts and learned the OB was a 70 model.  Dont know what first gear ratio it has yet tho
Offline PlumCrazy
« Reply #2 on: May 22, 2007 - 02:51:34 PM »
PP 8333149      0004
PP833 New Process 4 speed
3149 March 12th 1970
0004 Fourth Transmissin built on March 12th
« Reply #3 on: May 22, 2007 - 04:13:59 PM »
Thanks plumCrazy,  That was very helpful. I wish the trans was made in 69, my car was built the first month or so of 70 barracuda production. But it really doesnt matter. But one more question you may know. Is the gear ratio the same in both small and big block 4 speeds? And what might the first gear ratio be?
Thanks for your help....ALAN
« Reply #4 on: May 22, 2007 - 11:56:23 PM »
318 -383 used the same ratio gear set , 440-426 used the 18 spline
 first gears will be in the 2.5 -2.6 range
Alaskan_TA
« Reply #5 on: May 24, 2007 - 09:55:34 PM »
It is from a 1970 Barracuda or Cuda.
