Author Topic: Ozcuda's 70 Barracuda  (Read 14131 times)
Offline farmboy70
Re: Ozcuda's 70 Barracuda
« Reply #60 on: December 16, 2007 - 10:02:13 AM »
Car looks great, keep up the good work.
Are you using the original drum brakes? I see you have a drum brake master cylinder.
Offline OzCuda
« Reply #61 on: December 27, 2007 - 06:08:37 AM »
Made some good progress today.  Finished fitting the wiring to the engine bay (car is done exept for fitting a stereo and some inevitable fault finding), refitted the CA vapour return line which was originally going to be left off the car, and connected up the trans to the selector.  Discovered the the steering column lockout won't fit with the TTI extractors - will this be a problem??
Engine bay is as finished as I can get it, rest is up to the mechanics to get it running.  I've gotta say that working under a Barracuda is so much harder than the Jeep - would've loved to have access a hoist today!  :working:
Dave, car still has original rear drums, factory discs up front.
'70 Barracuda
Offline hemiken
« Reply #62 on: December 27, 2007 - 06:59:56 AM »
 :clapping: Loooooking Sweeeeeeet man. :droolingbounce:
Offline hezzel
  • Matching numbers 383 Magnum ,727 at and 3:23 rear
« Reply #63 on: December 27, 2007 - 08:15:43 AM »
1971 Dodge Challenger R/T
2019 Toyota Rav4 Hybrid
Offline Black340
  • 1973 challenger 340 4 Speed
« Reply #64 on: December 27, 2007 - 03:38:58 PM »
Looking great  love the color :clapping: :clapping:
Offline farmboy70
« Reply #65 on: December 27, 2007 - 06:35:04 PM »
From the picture it looks like you have a drum brake master cylinder, that will not have enough fluid capacity for disc brakes.Not picking just worried about safety.
Offline OzCuda
« Reply #66 on: December 27, 2007 - 06:47:07 PM »
Dave,  I have just re-used the master cylinder that was on the car and it has factory front discs???  Brakes were functional before disassembly but I only drove the car twice - implications ???
'70 Barracuda
Offline farmboy70
« Reply #67 on: December 27, 2007 - 06:52:50 PM »
The cap looks like a drum brake one but if it has two different size reservoirs you are OK. If they are the same size it is a drum one and you should change it. It may work until the brakes wear, and as the pistons in the calipers move out it will need more fluid and the master cylinder will go dry. The brakes will fail to work in the front. Defiantly check this out.
« Last Edit: December 27, 2007 - 06:55:48 PM by farmboy70 »
Offline farmboy70
« Reply #68 on: December 27, 2007 - 07:08:01 PM »
Here is a picture of the  disc brake one. The rear reservoir is the larger one for the front brakes.
« Last Edit: December 27, 2007 - 07:14:37 PM by farmboy70 »
Offline OzCuda
« Reply #69 on: December 27, 2007 - 07:11:53 PM »
Thanks Dave, I'll check it out.
'70 Barracuda
Offline 426HEMI
« Reply #70 on: December 27, 2007 - 07:35:01 PM »
Not only not having the brakes not work right because the drum brake master cylider is made different than the disk brake master cylinder.  The drum brake master cylinder has a valve in them to hold pressure on the drum wheel cylinder so it will not leak.  It will keep pressure on the caliper if installed that way.  The disk master cylinder has no pressure valve in it so the fluid flows freely.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline OzCuda
« Reply #71 on: December 27, 2007 - 07:58:18 PM »
This is what I have - guess I'm looking for another master cylinder  :crying:
'70 Barracuda
Offline FJ5_440
  • Wisconsin
« Reply #72 on: December 27, 2007 - 08:17:51 PM »
That is the kind of thing that makes this site so great.  You get so many guys who know what they're doing looking over your project that they catch stuff like that before it causes other problems.
** Shane **
Offline OzCuda
« Reply #73 on: January 04, 2008 - 05:35:33 AM »
Well, today I finally got to take the 'drivers' seat of the Barracuda for the first time in nearly 3 years!  All I could see was this huge hood spread out in front of me and I'm 6'3" - its going to be some sort of ride once the 383 is in full song.  Speaking of which, car goes in tomorrow to get the engine run-in and trans, steering and brakes all up and running so hopefully by next week she will be alive  :clapping:
Over the last few days have got the mirrors, wing supports, splash shields, rear bumpstops, door glass (broke a slider so will now have to wait), window clips and floor bungs in.  Was meant to go from the mechanics straight to the trimmers but will now hold off a week or two until all the interior trim can be done together.  Could it be that I am only a month  or two away from completion??  :woo:
'70 Barracuda
Offline hemiken
« Reply #74 on: January 04, 2008 - 06:04:16 AM »
 :woo: Car is looking absolutely beautiful buddy :clapping:
Can you take a picture from your view sitting in the seat looking over the hood and post it please.   :2thumbs:
:burnout:
