Author Topic: Air compressor advice  (Read 1055 times)
Offline ChallengerHK
« on: May 23, 2007 - 10:27:41 AM »
I've just bought a house (for the first time, pics to be posted as soon as I find where I packed the cable for my digital camera) and one of my first purchaes is going to be an air compressor. I need to find out what kind of specs I need to look for in terms of pressure, flow and tank size. Early on I'll be doing general wrenching, like the suspension upgrade I've been working toward.
- Han Solo, Star Wars
Offline wiging19
Re: Air compressor advice
« Reply #1 on: May 23, 2007 - 11:07:32 AM »
 :naughty:  Good question.  I'm interested in the answer to this question.
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #2 on: May 23, 2007 - 11:37:26 AM »
There are a lot of good threads here about this.  Just do a search on compressors.  Here is just one:
http://www.cuda-challenger.com/cc/index.php?topic=18841.0
When I bought my compressor, I didn't want to have to buy another.   I went for a two stage, aimed for a 80 gallon tank, and highest cfm I could afford.  I knew I would want to run a small blast cabinet and that is usually the most demanding tool you can attach to a compressor.
Offline miketyler
    • www.miketyler.net
« Reply #3 on: May 23, 2007 - 04:39:08 PM »
yup - if you plan on doing body work your tools will have a high CFM demand. You should settle for nothing less than a two-stage unit. No cheap oil-less models. They just can't keep up. I am using a three cylinder two stage 220V unit on a 25GAL tank. It does pretty well for my needs
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline matt63
« Reply #4 on: May 23, 2007 - 05:38:05 PM »
Don't base your comparisons on hp as these ratings are mostly marketing gimmicks.  How can you possibly run a 5 hp compressor on 110v?  A real 5 hp compressor will put out closer to 4 cfm per hp.  My Campbell Hausfeld 5 hp 110 volt 30 gallon tank unit is a great little unit but it will not keep up with a rotary sander where as a proper 5 hp unit will.
Matt in Edmonton
'68 Valiant
« Reply #5 on: May 24, 2007 - 05:50:10 AM »
All good advice, thanks. Having just taken out a mortgage, I may not be able to afford what I really need to get. I might have to start cheap and upgrade later. for the record, my bodywork skills are awful, so I don't think I need to worry about that.
Offline BIGSHCLUNK
« Reply #6 on: May 24, 2007 - 06:53:41 AM »
Check out a few auctions, sometimes when shops close up some of the bigger stuff goes very reasonably cause the demand is not as high. -SOMETIMES-  :bigsmile:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #7 on: May 24, 2007 - 06:59:23 AM »
Thanks, schlunk, I've been in contact with a shop closing down from craigslist. Wish me luck.
