Author Topic: Anyone runs with concrete in engine block..???  (Read 6552 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: May 23, 2007 - 03:47:49 PM »
My race 470cui. is filled to the freeze plugs with concrete.
Thinking of making it "street", can I get cooling on it for that...
« Last Edit: May 24, 2007 - 03:13:27 PM by cowboy »
Offline go-fish
Re: Anyone runs with concrete in engine block..???
« Reply #1 on: May 23, 2007 - 04:31:07 PM »
If it is only filled to the freeze plugs you could do some cooling system redirection. There are some freeze plugs that have AN fittings that feed water to that portion of the block first. There is a good topic on moparchat.com that deals with cooling modifications in the Circle Track forum. Circle track cars are very demanding on the cooling system. http://www.moparchat.com/forums/showthread.php?t=70569&highlight=cooling+modifications
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #2 on: May 24, 2007 - 03:12:49 PM »
Just tryed to read me trough the posts, but did not plan to go that hi-tech...
Just wanna know if, with the rigth radiator, will it work...???
Offline moper
« Reply #3 on: May 25, 2007 - 09:36:13 AM »
You have block filler..it's not concrete...lol. It acts like iron, not cement. To answer you, it's put in to help stabilize either bore walls, or main webbing, or both. You have a "short fill", which is mainly main webbing. You lost a bit of your cooling system volume and surface area with that fill. So you need to build thinking that way. A biogger radiator than even the booxs say you need, and no engine with block fill should be run without an oil cooler if it's street driven. Oil works as much or more than antifreeze to cool the parts. So use a cooler (looks like a good trans cooler) and you're fine.
