Author Topic: need help with pedals  (Read 1042 times)
Offline cudachuck
« on: May 23, 2007 - 09:11:48 PM »
how do you get the spring on the clutch pedal there has to be a easy way thanks
Re: need help with pedals
« Reply #1 on: May 24, 2007 - 01:15:07 AM »
see other post
Offline ShelbyDogg
« Reply #2 on: May 24, 2007 - 10:01:46 AM »
I usually pull the rubber bumper stop out then use a big craftsman screwdriver to pry it on there.  If that doesn't work, you can always pull the pedal assembly out to put it in.    I have a couple of sets laying around and ALWAYS have to tie the spring to the pedals or it just falls out.  With the pedals out, The floor isn't there to stop the pedal from releasing the spring.   I hope you don't have to go that far to get it in though.
Offline cudachuck
« Reply #3 on: May 24, 2007 - 02:39:10 PM »
does anyone have a picture of what its suppose to look like thanks
Offline ShelbyDogg
« Reply #4 on: May 24, 2007 - 10:05:24 PM »
Here are a few.  You'll notice that if the pedal moved far enough (without the floor)  the spring falls right off.
Offline ShelbyDogg
« Reply #5 on: June 08, 2007 - 05:39:30 AM »
Herb McCandless said how to do it the easy way at the Power Tour bar-b-que put on by the Memphis Mopar Club June 7th.
Put the small end in a vise.
Pull the long end to the right and fill the left side with washers between the coils.
Pull the long end to the left and fill the right side with washers between the coils.
Put in enough washers to extend the spring long enough to go over the pedal pivot.
Pull out the washers.
No prying needed.   Herb is a Mopar God. I was lucky to stay at the same Hotel and caravan with him and his wife on the Power Tour.
Offline Finoke
« Reply #6 on: June 20, 2007 - 05:48:50 AM »
I've tried this and it works like a charm
