it really doesn`t matter where the rotor is pointed so having the dist drive pointed where you have it is fine , you need to line up the relucotr & the pick up then advance the dist a few degrees , put the #1 wire on the tower that the rotor is pointed too , wire the rest in sequence & it will fire up
