Author Topic: How to check your wiper switch?  (Read 1214 times)
Offline Scatterbrain
  • 1973 Challenger
« on: May 26, 2007 - 07:12:45 PM »
My wipers worked when I first got the car a few weeks ago, then they stopped after I messed with the dash the first time.  I have since replaced the motor (One of the motor wires disconnected when I was checking them and I couldn't figure out how to get it connected again), but I still don't get any movement out of the wipers.  I have power going into the switch, but it doesn't seem to be engaging the motor.
Offline Challenger6pak
Re: How to check your wiper switch?
« Reply #1 on: May 26, 2007 - 08:47:14 PM »
Not to sound like a wise crack but, have you checked to see if you have power coming from the switch to the motor?  It may not be a direct wire from one to the other.  Do you have a wiring diagram to help?
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #2 on: May 26, 2007 - 10:48:50 PM »
switch panel must be grounded
  • 1973 Challenger
« Reply #3 on: July 17, 2007 - 09:46:23 PM »
ok, switch panel is grounded.  I get power going into the switch, but nothing at the connector coming out of the firewall to the wiper motor.  I traced the wires back with the wiring diagram and there doesn't seem to be any power coming out of the switch.  The wiper motor is new, which wires can I hook up to test the motor?  There are four wires (red, dk blue, dk green and brown).  It looks like it may be the switch, anybody sell the 3 spd switch that isn't demanding your first born?
Offline Aussie Challenger
« Reply #4 on: July 18, 2007 - 04:25:17 AM »
  My wipers don't work, 1970 2 speed, I haven't had time to check anything out yet.
I noticed that my wiper motor had a resistor on it, it looks the same as a ballast resistor.  On the wiring diagram I downloaded I didn't see a resistor in that circuit.
 :popcorn:  Thanks for any help or info.  :bigsmile:
Offline ShelbyDogg
« Reply #5 on: July 18, 2007 - 09:11:45 AM »
Always make sure that you put the bottom screw in that hold the switch assembly.  That is where it gets it's ground.
