Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Will the Piston Hit the Head
« previous
next »
Print
Pages: [
1
Author
Topic: Will the Piston Hit the Head (Read 609 times)
nivvy
Guest
on:
May 27, 2007 - 11:08:11 AM »
I am getting a good deal on eddy stage 3 ported heads and my question i will the piston hit the head and what would my compression be...
http://www.csgnetwork.com/compcalc.html
4.375 bore
4.150 stroke
4.380 head gasket bore
.065 head gasket thickness
84 cc's
-6 pistons
.013 above deck
i guess depending on the gasket thickness i use will determine if the piston hits....I believe the .013 is above the deck...
dont I want .040 minimum between the piston and head to achieve good quench...
Last Edit: May 27, 2007 - 11:10:03 AM by StrOkEr
Logged
Mopar God
Jr. Member
Re: Will the Piston Hit the Head
Reply #1 on:
May 28, 2007 - 09:01:11 AM »
Stroker,
With steel rods, your quench distance should be fine @ 0.052" calculating your +0.13" deck and 0.065" head gasket thickness.
I have run steel rod engines as tight as .025" although it is not recommended...Robert
Logged
matt63
Sr. Member
Reply #2 on:
May 28, 2007 - 09:33:28 AM »
I did some research on this when I built my 408 stroker. I believe that 0.035 - 0.045" is the goal so "zero decking" gets you there with std head gaskets. (0.035" is the minimum) Any more than clearance than this and the benefit of quench goes away fast.
Logged
Matt in Edmonton
'68 Valiant
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
