Author Topic: Overheating  (Read 5607 times)
Offline VTMopar
Overheating
« on: May 28, 2007 - 09:43:33 AM »
Help!    Took the Challenger out for the first road trip after overhaul about 300 miles (to Hemmings Car show in West Lebanon, NY).  She ran great -- but without the A/C hooked up (yet) -- she ran a bit the high side of the temp guage.   Belts seem tight enough -- radiator was tested before the overhaul -- coolant is new and level right where it was when I left.   Could it be the fan?
Any ideas on what might be going?
Vermont MOPAR
VT MOPAR
Re: Overheating
« Reply #1 on: May 28, 2007 - 01:39:33 PM »
Forgive my ignorance of your setup.  :banghead: What size engine, and what size radiator? How many blades on the fan, and do you have a fan shroud?
Offline VTMopar
Re: Overheating
« Reply #2 on: May 28, 2007 - 05:10:01 PM »
All original -- 360 engine; 26 inch radiator w//shroud; 7 blade fan  -- went through the complete engine & bay this winter.....
Question:  Should the fan blade turn freely when the engine is cold/not running?    Belts are tight....
Also, was wondering if it could just be a bad thermostat?
Vermont MOPAR
VT MOPAR
Re: Overheating
« Reply #3 on: May 28, 2007 - 10:58:21 PM »
if the thermostat is bad it will cause this also timing too far retarded or carb too lean
Offline Mopar73340
Re: Overheating
« Reply #4 on: May 29, 2007 - 01:19:58 PM »
Fan should should not turn free when the engine is cold or warm. There should be some resistance. Also from experience if you replace the fan clutch, make sure you go with the heavy duty one for the 7 blade fan as the std duty one will not spin the 7 blade fan fast enough for proper cooling. My 340's run 185* on 90*+ days with 7 blade fan, heavy duty clutch and 26" radiator with the A/C on. Just my  :2cents:
Re: Overheating
« Reply #5 on: May 29, 2007 - 02:43:47 PM »
Some thermostats are more restrictive than others, I have read that Mopars need the low restriction type to flow correctly.
Offline pink panther
Re: Overheating
« Reply #6 on: May 29, 2007 - 03:03:13 PM »
cheapest place to start with the thermostat
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Overheating
« Reply #7 on: May 29, 2007 - 03:20:58 PM »
u using the factory guage?
Offline VTMopar
Re: Overheating
« Reply #8 on: May 29, 2007 - 08:41:52 PM »
Thanks for the thoughts -- will start with the thermostat -- Yes, the factory guage -- it is accurate.
Vermont MOPAR
VT MOPAR
DJW
Re: Overheating
« Reply #9 on: June 01, 2007 - 08:07:47 PM »
It was the fan thermo-clutch.....   glad we found it!    Thanks for all the advice!
Vermont MOPAR
Offline miketyler
    • www.miketyler.net
Re: Overheating
« Reply #10 on: June 03, 2007 - 04:07:25 PM »
Thats great  news. I now have my car all put together and it still runs a little hot. We drove it around the neigborhood today and it crept up to the upper end of the operaitng range. My car is a 340 with a stock cam. It also has a newly revamped 3core radiator and dual electric fans. It seems to be doing a bit better than it did last year when I last drove it.  I appreciate everyones help and advice on that topic I started last year called 'cooling the engine down"
I will double-check timing this evening but how critical is the carburetor tuning? I am still running the Holley Street Avenger and haven't touched it since I know little about them.  If it could be contributive, how can I test and/or eliminate it? Replace the carb or ?  Are vacuum leaks contributive to higher engine temp?
« Last Edit: June 03, 2007 - 04:28:01 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Re: Overheating
« Reply #11 on: June 03, 2007 - 10:11:13 PM »
timing , running lean & vacuum leaks can all cause increased heat , the last can kill the engine quick
Offline ted
Re: Overheating
« Reply #12 on: June 04, 2007 - 09:36:43 AM »
And you know this how?
Quote from: Vermont MOPAR link=topic=33881.msg340029#msg340029
date=1180485712
Vermont MOPAR
Re: Overheating
« Reply #13 on: June 05, 2007 - 07:16:13 AM »
a vacuum leak can increase heat in a cylinder just like adding oxygen in a oxy actelene torch , it can melt the plug or even the piston if left lean
Offline miketyler
    • www.miketyler.net
Re: Overheating
« Reply #14 on: June 05, 2007 - 11:13:10 AM »
that makes a lot of sense to me. The carb piece of this is the only thing I haven't changed. Will give that a go.
72' Cuda restomod
70 Mustang Mach 1
