Does anyone know a better way to cut open doors besides an X-acto knife? A dremel tool makes the gaps too wide.
I've used several different ways for cutting out panels.
Take and thin the plastic first on the inside.
Then use either a razor saw, or a hot wire to cut the panels out.
If you try the hot wire route, get the hang of a hot wire first before cutting an expensive kit up. They can wander if your not careful.
I've also seen a guy cut a door out using string.
Yes string! The same kind that one would fix a button with.
Just keep pulling a length through the area you wish to remove and the friction of the string cuts away the material slowly.
The key will all routes is patience.
If you do cut out an area by mistake, build up the edge again using super glue as a putty/filler.
Make sure that you sand it to shape within a day or so of applying it, other wise you will never be able to sand only the glue as it will be harder than the plastic its bonded to.
