Author Topic: Steering Column Removal?  (Read 2013 times)
Offline cudadude013
    • Friday at the Lake
« on: May 28, 2007 - 02:33:55 PM »
How do I remove the steering column from within the Engine bay? I've pulled the interior and the dash and the steering column is all thats left, but I haven't been able to figure it out. Thanks
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: Steering Column Removal?
« Reply #1 on: May 28, 2007 - 02:54:02 PM »
You have to drive out the drift pin in the coupler. And unbolt the column from the floor inside the car.
Dave  :wave:
Worlds first e-body trailer.    Severna Park, Maryland
« Reply #2 on: May 28, 2007 - 04:01:01 PM »
You will need a punch for that pin.  :stomp: I used one of my "not worthy" tie down's (T-shaped)from my valve covers. It worked like a charm... along with a hammer.  :thumbsup:
Offline cudadude013
« Reply #3 on: June 01, 2007 - 11:23:13 AM »
Is the steering column supposed to come loose when I pull the pin? I pulled the pin and nothing is happening. Am I missing something? :clueless:
Thanks for the responses
« Reply #4 on: June 01, 2007 - 02:45:36 PM »
Once you pull that pin, you should be able to move the steering column at least a foot or so into the car. Maybe that big knuckle is still hung up on the steering box?? It might be hammer time.  :grinyes:
Offline purple1
« Reply #5 on: June 01, 2007 - 05:46:36 PM »
You may need some one pulling on the inside, at the same time as you hammer on it. But if you got the pin out, it will come out.  :2thumbs:
Dave  :wave:
« Reply #6 on: June 01, 2007 - 06:08:59 PM »
a BFH & some penetrating oil on the coupler/splines should do it if the pin is out
and I suppose you took the 3-bolts out at the firewall.  :clueless:
« Last Edit: June 01, 2007 - 06:10:50 PM by bullitt99 »
Offline cudadude013
« Reply #7 on: June 07, 2007 - 12:13:48 AM »
The penetrating oil worked like a charm. Thanks guys! Now when I look in my engine bay all I see is a K frame. I can't wait to see everything put back together completely restored!
