Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Small block valve train alignment issue.
« previous
next »
Print
Pages: [
1
Author
Topic: Small block valve train alignment issue. (Read 810 times)
torredcuda
Sr. Resident
Epping NH joined 11/23/03
on:
May 28, 2007 - 03:21:40 PM »
I have stock 915 heads with Crane ductile iron adjustable rockers and while assembling things noticed that some of the rocker tips don`t align in the center of the valve tip.The rockers are held out against the stock spacers using springs in between them and I`m wondering if they could be more centered using spacers instead of the springs.I`ve been running them this way for years but am I doing any damage or is it no big deal?Are there spacers available or do I need to custom make them?I noticed a pic of the stock 273 setup and they use spacers.
Logged
Jeff
72 Barracuda 340/4spd Torred
70 roadrunner 383/auto In-Violet
70 Duster 360/auto drag car (Petty Blue soon)
04 Ram 2500 5.7 Hemi
ntstlgl1970
Resident
T a c o c a t
Re: Small block valve train alignment issue.
Reply #1 on:
May 28, 2007 - 03:38:52 PM »
Can you take a picture? Maybe the spacers got mixed up if you had the rockers off the shafts?
Logged
torredcuda
Sr. Resident
Reply #2 on:
May 28, 2007 - 03:45:54 PM »
I`m charging the camera batteries and i`ll get a pic up as soon as I can.There are no spacers provided with the Crane set,just springs to hold them out against the factory hold downs.
Logged
Jeff
torredcuda
Sr. Resident
Reply #3 on:
May 28, 2007 - 04:03:57 PM »
Harland Sharp sells shims in different widths under repalcement components.Wonder if they will work for me?
http://www.harlandsharp.com/
Logged
Jeff
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
May 28, 2007 - 11:24:39 PM »
Mopar sells packs of shims as well if you want to remove the springs entgirely you need a spacer ring the correct width
Logged
LAA66
Sr. Member
Reply #5 on:
May 29, 2007 - 06:50:55 PM »
I made custom spacers from aluminum.Trouble is after a while the soft metal wore. Recently installed valve spring shims to compensate w/0.875 ID. Use a hardened material if you go the positive spacer route.
Logged
torredcuda
Sr. Resident
Reply #6 on:
May 30, 2007 - 06:36:00 PM »
I`m ordering a selection of spacers from Harland Sharp and will custom grind them to the sizes I need for alignment.
Logged
Jeff
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
