Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Hurst Pistol Grip
« previous
next »
Print
Pages: [
1
Author
Topic: Hurst Pistol Grip (Read 728 times)
roy282
Jr. Member
Hurst Pistol Grip
on:
May 28, 2007 - 06:42:52 PM »
I have Two questions about hurst shifter ( pistol grip ) . One how do you remove the lens at the top of the shifter and how can you tell if its aftermarket or original the main part where its written HURST? can't seem to find any # ??
Logged
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
AMXguy
Sr. Member
Re: Hurst Pistol Grip
Reply #1 on:
May 28, 2007 - 07:42:31 PM »
The lense just sticks in there with an adhesive, I screwed mine up trying to get it out and had to get a new one. I'm told the Hurst logo is larger on the newer ones but I'm not sure.
Logged
1970 R/T SE Challenger
1970 Superbee
1969 S code Mach 1
1967 GTO
Carlwalski
C-C.com Expert
Reply #2 on:
May 28, 2007 - 07:45:54 PM »
The lens is glued on to the top bezel then the bezel is penned into the shifter below the lens. Drill a small hole into the old lens and run a drywall screw or similar into the lens to pull it out. This way you will not damage the bezel. You may or may not need glue/adhesive to secure the new lens, some fit straight in perfectly snug.
Not sure on part numbers sorry.
Logged
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Hurst Pistol Grip
