Author Topic: Seat Belts  (Read 2653 times)
Offline Moparchadwy
  • Finally got my dream car! 74 'Cuda
Seat Belts
« on: May 28, 2007 - 09:01:41 PM »
I thought before I start my next project on my car I would get help from all the "Mopar Brainiacs" on this sight. How difficult is it to add aftermarket 3-point seat belts in my 74 Cuda?
Offline matt63
Re: Seat Belts
« Reply #1 on: May 28, 2007 - 09:17:10 PM »
I'm not sure if the my '73 is the same as '74 but I added the Wesco 3 point retractable belts.  They aren't stock replicas but they look good (and new). http://wescoperformance.stores.yahoo.net/resebe.html  I did it a couple of years ago so I don't remember the details but I believe they bolted right in.
Matt in Edmonton
'68 Valiant
Offline 360 'CUDA
Re: Seat Belts
« Reply #2 on: May 28, 2007 - 09:29:41 PM »
Is this a trick question ?
All 74s came with 3 point belts.   Even so, most people find the stock setup in '74s too sensitive.
NZ has a nice aftermarket set of belts in his car  :2thumbs:
« Last Edit: May 28, 2007 - 11:21:31 PM by 360cuda »
Offline Moparchadwy
Re: Seat Belts
« Reply #3 on: May 28, 2007 - 10:26:10 PM »
Not a trick question. My Cuda only has lap belts and no sign of there ever bieng 3-point belts.
Offline 360 'CUDA
Re: Seat Belts
« Reply #4 on: May 28, 2007 - 11:20:39 PM »
OK so someone changed them out, probably long ago. All Mopar passenger cars got the 3 point system in 1974. I think you can get away with the seatbelt setup out of a '74 B-body as they look very similar. I have never measured them but I still have the set out of my '74 Charger I could check out for you.
The seatbelts are the easiest way to tell a '73 from a '74 'CUDA or Challenger without looking at the VIN
Check if you have the special rear interior panels that house the driver's and passenger's shoulder seatbelt retractors. The '74 only interior panels have little slots below  the armrests that let the belt go through.
It sounds to me like you need those too.
« Last Edit: May 28, 2007 - 11:25:09 PM by 360cuda »
Offline Stacked440
Re: Seat Belts
« Reply #5 on: May 30, 2007 - 09:24:06 AM »
I put the wesco performance conversion van seat belts with the 7" drop sash in my car, they bolt into stock holes and are REALLY nice.  Lemme know if you'd like some pics.
-Kyle-
Offline kingtroll
Re: Seat Belts
« Reply #6 on: May 30, 2007 - 10:18:31 AM »
I'd like some pics.....I have to replace my seat belts on mt 74. I have the cut outs in the side rear panels for the seat belt mounts.
Thanks
1974 Barracuda
Offline Stacked440
Re: Seat Belts
« Reply #7 on: May 30, 2007 - 09:52:26 PM »
Sorry the first pic is a little crappy, reused all stock mounting holes, they are quite comfortable. :thumbsup:
-Kyle-
Offline kingtroll
Re: Seat Belts
« Reply #8 on: May 31, 2007 - 01:40:46 PM »
Looks good to me... :2thumbs:
1974 Barracuda
Offline Moparchadwy
Re: Seat Belts
« Reply #9 on: June 18, 2007 - 09:57:31 PM »
Can anybody tell me if I decide to put a 4-point harness in my 74 Cuda if I will be able to use the stock seat belt mounting holes?
Offline 360 'CUDA
Re: Seat Belts
« Reply #10 on: June 19, 2007 - 12:01:06 AM »
I am using the stock holes for my lap belts on '72 but the shoulder belts are bolted to the roll bar in the correct position per NHRA
Offline RaptorF229
  • A work in Progress
Re: Seat Belts
« Reply #11 on: July 25, 2007 - 02:22:51 AM »
Which wesco kit did you get the hardtop or standard? Or are they the same?
Offline GreenFish
Re: Seat Belts
« Reply #12 on: July 30, 2007 - 02:52:37 PM »
I just ordered a set from xv motorsports. They look just like these wescos. xv charges 139 + shipping. for the pair.
Offline RaptorF229
Re: Seat Belts
« Reply #13 on: July 30, 2007 - 11:35:40 PM »
I ordered the Xv ones also. Can't wait to get them
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
Re: Seat Belts
« Reply #14 on: October 13, 2007 - 12:43:00 PM »
so how did the XV installations go?
are you happy with the results?
easy install?
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
