Author Topic: Converter stall speed question  (Read 1045 times)
Offline BIGSHCLUNK
« on: May 29, 2007 - 09:22:10 PM »
I finally got my carb issues worked out or so it seems.  :thumbsup: So I have moved into another area. I never did know what rear end gears Nikki had so I finally jacker her up/turned the tires/counted the spins on the driveshaft. Just short of 3 and 1/4 turns. I'm equating this to 3.23 ok? Well for 3.23's I turn alot of rpm's on the highway. At around 65 MPH  I'm turning about 3800 R's (seems high too me  :clueless:) Also noticed when you initally back out of te garage the trans is a little slow to respond (not slipping) Once your going no further issues. Am I nuts or what? As always thanks in advance.
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Converter stall speed question
« Reply #1 on: May 29, 2007 - 10:13:36 PM »
sounds like a bad tach or speedometer that is way off.
« Reply #2 on: May 30, 2007 - 12:42:22 AM »
Offline tactransman
« Reply #3 on: May 30, 2007 - 04:53:51 AM »
Sounds like converter drain back,when it sits the converter drains the fluid out of it.(back into the pan) when you start it in park,it doesn't start to refill it till you put in neutral or in gear,it is totally normal.
Terry-tactransman
Union, Mo.
Offline BIGSHCLUNK
« Reply #4 on: May 30, 2007 - 07:23:35 AM »
I guess  :dunno:  I'll hook up the dwell tach and compare it to the dash tach. Wrong gear in the trans for the speedo maybe??   :clueless:
Darn used cars you never know what you get  :roflsmiley:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline tactransman
« Reply #5 on: May 30, 2007 - 07:37:53 AM »
If I remember correctly, 3.23's should have around a 30-32 tooth speedo gear. :thumbsup:
Terry-tactransman
Union, Mo.
Offline BIGSHCLUNK
« Reply #6 on: May 30, 2007 - 07:55:44 AM »
tac I appreciate your imput!  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline 422STROKER
  • Member Since 6/3/06
« Reply #7 on: May 30, 2007 - 07:08:27 PM »
Those new fangled portable GPS units are good for checking actual MPH.
Tom :2thumbs:
Tom
Offline BIGSHCLUNK
« Reply #8 on: May 30, 2007 - 08:56:01 PM »
Today I remembered a spot on the freeway were the Sheriff has one of those radar detectors set up that show your speed and flash if your over the limit. Gonna do a little "testing"  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
