Author Topic: Speedometer gear  (Read 1924 times)
Offline 6packCuda
Speedometer gear
« on: May 30, 2007 - 10:31:44 AM »
My speedo is waaaaaaaaaay off. Which gear do I need with 3.55s and a 727?
Offline rallyechall
Re: Speedometer gear
« Reply #1 on: May 30, 2007 - 11:10:23 AM »
Here is a quicky chart. you also need to know the tire size...
http://www.jimsautoparts.com/transmission_parts.htm
« Reply #2 on: May 30, 2007 - 03:33:07 PM »
Are you way off fast, or way off slow? I had to change my speedo gear once. It's a little messy and stinky, but not a bad job. You do need to know your tire size though. I can talk you thru it, if you don't know what to do. I'll guess you need something in the 35-40 tooth range.
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #3 on: May 30, 2007 - 03:45:28 PM »
Oh, and don't forget the new o-ring. :thumbsup:
Don't ask me how I know.  :pullinghair:
Dave  :wave:
Worlds first e-body trailer.    Severna Park, Maryland
« Reply #4 on: May 30, 2007 - 05:12:09 PM »
here is a spreadsheet that will figure it out for you...need rear tire size too
http://www.moparts.com/Tech/tech/img/AUTOMATICchart.xls
Offline 6packCuda
« Reply #5 on: May 30, 2007 - 06:08:50 PM »
Thanks guys. I know how to change the gear, just don't know which gear I need. The rear tires are 275s. The speedo reads high. When I'm following other cars that are going 60-65, my speedo reads 85-90mph.
« Last Edit: May 30, 2007 - 06:18:45 PM by 6packCuda »
Offline 6packCuda
« Reply #6 on: May 30, 2007 - 06:17:08 PM »
Thanks bullitt99. That is very helpful. I come up with 33.82
So I guess I need a 34 tooth gear. Right?
« Reply #7 on: May 30, 2007 - 06:49:01 PM »
I don't know your tire size  275 is width but aspect ratio & rim diameter have to be put in too.
something like 275/60/14 or 275/50/15  275/40/17  any change will effect the outcome a little.
Offline 6packCuda
« Reply #8 on: May 30, 2007 - 08:31:39 PM »
Yep, I put all that info in. They're 276/60/15s.
Offline Stacked440
« Reply #9 on: May 30, 2007 - 10:27:51 PM »
 :eek7:  That O-ring was harder to find than...well...hard to find!  Had to go to a specialty auto store just to find one the right size and thickness.  Then put it in only to find that the inner seal leaks :crazy:  I don't want to jinx it but it has stopped for the last few days... :angelwings:
-Kyle-
Offline purple1
« Reply #10 on: May 31, 2007 - 06:02:06 AM »
www.rockauto.com has them both.
Dave  :wave:
Offline tactransman
« Reply #11 on: May 31, 2007 - 06:30:32 AM »
I have plenty,if anyone ever needs 'em,they will fit in an envelope.  :2thumbs:
Terry-tactransman
Union, Mo.
Offline vinb
« Reply #12 on: May 31, 2007 - 03:56:44 PM »
275/60/15 Tire
3.55 Gear
Auto
67 mph @ 2900 rpm....
33 teeth , yellow gear...
Offline 74 340 4speed
« Reply #13 on: May 31, 2007 - 10:08:48 PM »
I just saw this thread and I need a new gear for my speedometer as well.  On the website that was listed earlier, http://www.jimsautoparts.com/transmission_parts.htm, it says that a gasket kit is needed whenever changing these out.  Is this only for automatics, or does it apply to 4 speeds as well?  I will be putting the gear in an A-833 four speed.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
