340 cam selection....
Author Topic: 340 cam selection....  (Read 2933 times)
Offline HemiOrange70
« on: May 31, 2007 - 09:34:25 AM »
Have a chance to get a Crane cam at a good price.
First is everyone happy with crane cams???
I want my 70-340 to be close to stock here are the specs.
Part Number: 150052 Grind Number: 272 H10
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1964 Up PLYMOUTH-DODGE-CHRYSLER 8 GOOD IDLE, DAILY USAGE, OFF ROAD, HIGHWAY TOWING, FUEL EFFICIENCY PLUS PERFORMANCE, 2600-3000 CRUISE RPM, 8.75 TO 10.0 COMPRESSION RATIO ADVISED. BASIC RPM 2000-5000
Engine Size Configuration
273-360 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 3027 @Valve 454 All Lifts are based
on zero lash and theoretical rocker arm ratios.
  Exhaust @ Cam 3027 @Valve 454
Rocker Arm Ratio 1.5
Good choice or not????
Thanks
Offline 74 340 4speed
Re: 340 cam selection....
« Reply #1 on: May 31, 2007 - 12:34:07 PM »
How is your engine put together?  What heads, intake, carb, igintion, compression do you have?  What gear are you running and what type of trans is in the car?  From what I can tell about the specs on crane's website (listed below), this would be a good cam for an almost stock engine.
Cam Timing: TAPPET @.004
Lift:   Opens Closes ADV Duration
  Intake 27 BTDC 65 ABDC 272 °
  Exhaust 67 BBDC 25 ATDC 272 °
Spring Requirements:   Triple   Dual   Outer   Inner
Part Number 99835
Loads Closed 113 LBS @ 1.600 or 1 19/32
  Open 290 LBS @ 1.170
 Recommended RPM range with matching components
Minimum RPM 1800
Maximum RPM 5200
Valve Float 5800
Cam Timing: TAPPET @.050
Lift:   Opens Closes Max Lift Duration
Intake 3 BTDC 33 ABDC 105 216 °
Exhaust 43 BBDC (7) BTDC 115 216 °
A side note, I found this on a cam chart on the internet.  It is the stock cam specs for a 68 340 equipped with a manual trans.
        duration @.050          valve lift            lsa            valve lash
A Eng.   P3412044     68 340 Man.-114      276/284      .444/.453"   112      Zero
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
« Reply #2 on: May 31, 2007 - 01:26:14 PM »
stock ignition-points, stock compression, (9.5/10-1) 650 4 barrell, 904 trans with shift kit and stock convertor, 2.02 j heads stock bore.
« Reply #3 on: May 31, 2007 - 11:45:47 PM »
Wouldn`t be my choice , I would use a more modern grind like a K54 Engle , it will idle like stock & work better
Offline Mopar God
« Reply #4 on: June 01, 2007 - 07:02:31 AM »
True, the Engles are good pieces, but I am partial to custom designs. I haven't used an off-the-shelf camshaft gring since 1988.
The camshaft you describe would be a good choice for a stock engine and perhaps, even a mildly modified one. To be sure you get the right profile, you would need to describe your entire combination to include how you will drive the car. For your compression, carburetion and street useage, I would probably use employ .450"/.450" lift and 215°/221° @ .050" on a 110.5° LSA.
That's just a ballpark guesstimate, but I have used this camshaft in 273's with very good results...Robert
