Author Topic: 4 speed tailshaft question  (Read 938 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« on: May 31, 2007 - 09:55:58 AM »
I have read a couple of threads on this here but am still not a 100 percent certain of the answer. I am looking for an 18 spline 4 speed for my cuda, but dual mount tailshaft 4 speeds seem to be slim and very expensive. I have read that there are 2 different bearings for the earlier 18 spline 4 speeds, a 307 and a 308 bearing transmission. My question is will the dual shift mount tailshaft fit on both of these, and if not which one should I look for and how to identify it? Also if it will fit on both, but one needs a bearing change which one needs the bearing change and what bearing goes in its place?
1996 Dodge Viper GTS Coupe
Offline Pistol Gripper
Re: 4 speed tailshaft question
« Reply #1 on: May 31, 2007 - 11:33:44 AM »
This is a good breakdown of the A-833.  Hope the info you need is in there.
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
P.G.
O ne
B ig
A $$
M istake
A merica
« Reply #2 on: May 31, 2007 - 11:38:51 PM »
the dual mount tial housing will fit both , , the rear brg with the dual mount tailhousing will be 308 , the front brg will be different
Offline 72hemi
« Reply #3 on: June 01, 2007 - 07:52:00 AM »
Will the front bearing make a difference when it comes to bellhousings?
« Reply #4 on: June 01, 2007 - 08:40:19 AM »
Yes & no , there is a 4.8" diameter retainer for the small brg so you can make the smaller brg fit any belhousing except the 5.2 OD
the other way is a problem though if you use a case with the 308 front brg the belhousing has to have a 4.80 hole , there is no way to get down to a 4.35 hole with the 308 brg
Offline 72hemi
« Reply #5 on: June 01, 2007 - 09:26:12 AM »
I have bellhousing number 2892513, do you know what hole diameter I have?
« Reply #6 on: June 03, 2007 - 10:16:27 PM »
No , I do not have a reference
