Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Should I use Slider or Pin style calipers?
« previous
next »
Print
Pages: [
1
Author
Topic: Should I use Slider or Pin style calipers? (Read 910 times)
Katfish
Resident
70 Challenger
on:
June 02, 2007 - 07:46:00 AM »
In the process of gathering parts for the factory 11.75" disc brake conversion on my Challenger.
Mopar Action's article says the Pin style is better,
BigBlockDart tech article says the sliders are better,
Neither really gives any reasons.
What should I use and why?
Thanks
Logged
PlumCrazy
Jr. Member
Re: Should I use Slider or Pin style calipers?
Reply #1 on:
June 02, 2007 - 09:59:24 AM »
I prefer pin over sliders, however sliders are way easier to find than 11.75 pin adapters.
Logged
Katfish
Resident
70 Challenger
Reply #2 on:
June 02, 2007 - 10:12:19 AM »
Why do you prefer the Pin type?
Thx
Logged
PlumCrazy
Jr. Member
Reply #3 on:
June 02, 2007 - 02:20:28 PM »
I can use everything from the correct year, hoses, calipers etc, do not have to worry abut remembering that the hose I need is from a 78 F body, the calipers are from a 75 A body etc.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
June 03, 2007 - 10:14:33 PM »
either works well
Logged
ntstlgl1970
Resident
T a c o c a t
Reply #5 on:
June 03, 2007 - 11:26:43 PM »
I've had sliders on my car for a number of years now, no problems. There are good pads made for both.....
Logged
wiging19
Full Member
Reply #6 on:
June 04, 2007 - 08:08:00 AM »
I had the slider ones with 11 inch disc's. I then upgraded to the pin ones when I did the 11.75 conversion like your doing. I like the pin ones better. The brakes wear evenly with the pin and the sliders tend to favor one side for brake wear. My car was orignally all drum and a convertible. It originally tended to slide alot during emergency braking. The Brake master set up I went to next helped significantly improve on that problem but the stopping ability wasn't as satisfying as I would like. Moving up to the 11.75 disc and adding the slider brakes was a step up in braking performance which I really liked. I'm very paranoid about brakes in cars since my dad owned english cars that constantly had brakes going out in them. So I am a little phobic about how solid my brakes are. Both systems do what you want them to do but I just feel the pins are a slightly better system. That is just based strictly subjective opinion with a little parania thrown in. Hope that helps.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
