Author Topic: 440 block casting help....  (Read 937 times)
Offline challenger71
« on: June 02, 2007 - 08:23:08 AM »
I am currently selling a 440 block and would like to find out what it originally came in.  The casting number is 3698830 440 7 and is dated 5/12/72.  There is also a stamping on the top that reads J 440 hp and then there are two 8's under that.  Any ideas, or where I could find the answer?
10 years in the making......
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: 440 block casting help....
« Reply #1 on: June 02, 2007 - 08:28:18 AM »
Those numbers won't tell you what it came in, just that it is a 72 casting that went into a 73 vehicle.
1996 Dodge Viper GTS Coupe
Offline 360 'CUDA
« Reply #2 on: June 02, 2007 - 10:25:33 AM »
Check to see if it has a VIN stamped on it. If it doesn't it's a replacement block and it didn't come in anything originally.
You can find the last six digits of the VIN on the machined pad, lower passenger side of the block by the oil pan rail
