Author Topic: loading up every mornining  (Read 7822 times)
Offline BIGSHCLUNK
Re: loading up every mornining
« Reply #30 on: June 07, 2007 - 09:15:56 PM »
You sure whoever rebuilt/adjusted this carb knew what they were doing?  :clueless: :clueless:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline ntstlgl1970
  • T a c o c a t
« Reply #31 on: June 07, 2007 - 10:50:33 PM »
This is what I was talking about with the breather. Did you find out if the pull off works yet?
sleepychallenger
« Reply #32 on: June 08, 2007 - 05:41:12 AM »
im pretty sure that he know what he was doing. as i say pretty sure, not positive.
sleepychallenger
« Reply #33 on: June 08, 2007 - 05:42:31 AM »
i still have to find a way to fix that hose. I will probably stop by the hobby shop today and get a vaccum pump to check the pull off and will let you know after lunch. No gas smell on the dipstick.
« Reply #34 on: June 08, 2007 - 08:39:57 AM »
just put a piece of hose on the pull off & suck on it if it is leaking you will know
Offline moper
« Reply #35 on: June 08, 2007 - 10:18:51 AM »
" You're Hired!!" :bigsmile:  :scared::roflsmiley:
sleepychallenger
« Reply #36 on: June 08, 2007 - 10:52:25 AM »
dont have any hose, i will go to the shop today at 4 and let you know after that
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #37 on: June 08, 2007 - 02:10:43 PM »
You can just "borrow" apiece from another place under the hood.  Make sure you put it back!!!!  :grinyes:
sleepychallenger
« Reply #38 on: June 08, 2007 - 07:43:42 PM »
i checked it earlier and the pull off is not working, it held no vaccume and didnt move at all when we sucked on ir or put the vaccum pump on it.
« Reply #39 on: June 08, 2007 - 07:48:31 PM »
Sounds like you may have found THE problem.  :thumbsup:
Offline BIGSHCLUNK
« Reply #40 on: June 08, 2007 - 09:42:11 PM »
Whoever did your carb should have checked that.  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
sleepychallenger
« Reply #41 on: June 09, 2007 - 03:20:18 AM »
no to get a new one
sleepychallenger
« Reply #42 on: June 09, 2007 - 03:20:35 AM »
:iagree: :dupe:
« Reply #43 on: June 09, 2007 - 05:21:22 AM »
Glad you found a problem!
Let's see what happens when you replace it...  :popcorn:
sleepychallenger
« Reply #44 on: June 09, 2007 - 05:22:55 AM »
looks like everywhere has to order the dang thing. what can i do in the mean time? can i just keep the choke open all the time, it hasnt been cold here in quite some time.
