Author Topic: loading up every mornining  (Read 7819 times)
sleepychallenger
Re: loading up every mornining
« Reply #60 on: June 15, 2007 - 09:23:43 PM »
NO 440 CARB!!!! i tried lots and lots of combos with the 750 CFM carb and it still always ran to rich for my motor. I have a hemi grind cam and a 30 overbore, thats it
Offline 440Charger
« Reply #61 on: June 15, 2007 - 10:02:07 PM »
ok, so the car is running better with the choke wired open, but when i come to a stop it surges and wants to die. also, if i run regular or midgrade unleaded the car deisles when i shut her down, doesnt ping at all, but deisles.  :feedback:
I just solved this same set of problems on my 440.  It doesn't try to shut off at the stop lights anymore, nor does it diesel when I shut it off.
I did the following:
1. Upped my timing from 6 to 13 degrees initial.  (the point is I increased it, 13 is just what my 440 likes, don't know for your 383)
2. Adjusted the carb idle mixture, and in my case it meant leaning it out a bit.  This only works AFTER getting the correct timing.
3. I idle around 700-800rpm.
Timing was everything in my case.
I love my 440...but it's not loving me back...yet
sleepychallenger
« Reply #62 on: June 16, 2007 - 06:59:45 PM »
will definately check the timing tomorrow. i just did the front disc swap today, need to finish bleeding the brakes can check the timing at the same time.
