loading up every mornining
Author Topic: loading up every mornining  (Read 7823 times)
Offline JCWCuda
Re: loading up every mornining
« Reply #45 on: June 09, 2007 - 09:06:20 PM »
I used to hold the choke open with a clothes pin , you'll just have to pump the gas a few more times to get her fired up
1974 Barracuda 360
2008 Ram 1500 Quad Cab 5.7l Hemi
1990 Jeep Cherokee 4.0l
Gone but not forgotten
1967 Barracuda 273
1976 Charger 318
2003 Dakota Quad Cab 4.7l
1988 Jeep Cherokee 4.0l
Offline BIGSHCLUNK
« Reply #46 on: June 09, 2007 - 09:27:56 PM »
Just keep it open for now. You may have to "play" with the pedal a bit till it warms up. Its warm enough in most places except maybe Alberta  :roflsmiley: Sorry Chryco...
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
sleepychallenger
« Reply #47 on: June 09, 2007 - 10:33:50 PM »
thanks all, i will let you know if this solves the problems
sleepychallenger
« Reply #48 on: June 11, 2007 - 06:32:32 PM »
ok, so the car is running better with the choke wired open, but when i come to a stop it surges and wants to die. also, if i run regular or midgrade unleaded the car deisles when i shut her down, doesnt ping at all, but deisles.  :feedback:
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #49 on: June 12, 2007 - 07:34:13 AM »
Just curious, not that it has to do with anything, but what is your compression ratio?
Try switching to a different brand of gas and see if it helps.  Do you need to run premium all the time?  If your compression ratio is high, you may need the premium fuel.
As far as the dieseling, to stop it you can give it a little gas when this happens to kill the engine.
See this link for causes: http://en.wikipedia.org/wiki/Dieseling
Offline tactransman
« Reply #50 on: June 12, 2007 - 07:41:03 AM »
Make sure your idle speed is not too high also.
Terry-tactransman
Union, Mo.
Offline moper
« Reply #51 on: June 12, 2007 - 08:29:37 AM »
What tac said.. Retune now with the choke open. Reset idle speed and mixture after timing is set. It should cure both.
sleepychallenger
« Reply #52 on: June 12, 2007 - 09:33:14 PM »
10:1 compression. i used to run regular before i swapped cams and then once i put in a new cam it started dieseling. My idle speed is pretty low, seems too low when i am in gear
Offline moper
« Reply #53 on: June 14, 2007 - 12:52:48 PM »
What is your timing set at? You may be just that..Idling too low, or have timing retarded.
sleepychallenger
« Reply #54 on: June 14, 2007 - 09:34:26 PM »
i think 3 degrees
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #55 on: June 15, 2007 - 09:41:05 AM »
thats pretty low.
sleepychallenger
« Reply #56 on: June 15, 2007 - 11:29:18 AM »
i thought that is what it is suppoesed to be?
sleepychallenger
« Reply #57 on: June 15, 2007 - 01:55:34 PM »
Well, i just checked my gas mileage with the new carb and hold on to your seats, i went from 9.7 MPG with the 440 carb to 15.1 MPG with the factory 383 carb. I love saving money at the pump!!!!  :bigsmile:
Offline 71bigblock
    • Steve's Mopars
« Reply #58 on: June 15, 2007 - 04:02:54 PM »
Holy shiite!  I get that with my 2 bbl!   :cooldancing: :ylsuper: :bananasmi
Offline moper
« Reply #59 on: June 15, 2007 - 05:05:46 PM »
Base initial timing should be set to 10-12° if you have no clue what the engine is built with. If it will start and doesnt ping that way, you could add more. I think the base factory spec was 8°. In any case, add the timing, then reset the carb. Then swap back the 440 carb, and see what it can really do.
