After he said yes, they are solid, I should have asked what did you use to make them solid?
yup, those are Mountain Dew and Dr. Pepper covered with plastic resin... but wait there's more... this was what my transmission tunnel was made of
that there is an Oklahoma plate from 1997 and what can you use to keep the outside air, heat and sound out with?
Insulation you say? Nope.
yup, a towel. There was more towel on the sides.
A friend and I worked all day to get the transmission tunnel in ... (don't make fun of our welds)
Gonna order a floor pan on Monday, then I can finish it up. Passanger's side wasn't bad at all, though Bubba did put more of that green plastic goop there. I wire wheeled it and found pretty much surface rust. I may just replace it anyway.
After this floor pan nonsense I can get get back to installing the Hot Rod Air.
