Author Topic: not charging  (Read 1101 times)
Offline pink340
not charging
« on: June 04, 2007 - 08:08:07 PM »
Hey guys... My cuda isn't charging... The original wiring harness is gone...  I know I can buy a new one but im Kinda tight.. I have done most the wiring from scratch but it still doesn't charge... I have a original 3 wire alternator I have the one big screw terminal hooked to the battery But where do the other two little one's go?? voltage regulator?? Im not sure im lost I hooked up one to the regulator and it made a buzzing noise along with some smoke... and renderd the regulator useless... anybody know how this goes??
thanks
Re: not charging
« Reply #1 on: June 05, 2007 - 01:23:41 AM »
I don't have my manual right now, but I believe both of the wires from the field of the alternator return to the voltage regulator.
Re: not charging
« Reply #2 on: June 05, 2007 - 07:18:24 AM »
you need a 12v feed to 1 field terminal & 12v to the reg , the second field wire goes back to the reg & grounds through the reg so the reg has to be properly grounded to the firewall
Offline pink340
Re: not charging
« Reply #3 on: June 06, 2007 - 04:52:38 PM »
Thanks guys it's running good now and charging.. How many volts should I have at the battery when it's running?
Re: not charging
« Reply #4 on: June 06, 2007 - 05:12:13 PM »
Around 13.8 volts, if all is well.
Offline GoodysGotaCuda
Re: not charging
« Reply #5 on: June 06, 2007 - 06:07:02 PM »
13.5-14.5v on average. mine tips a hair under 15v at cruise.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
Re: not charging
« Reply #6 on: June 06, 2007 - 07:49:11 PM »
Sounds like you got it - that's good.  There are wiring diagrams on this site if you use the search feature - I found 'em for my 73.  I just got done dealing with this same thing.  One of the field wires actually goes to a pretty big splice that then runs to a few different circuits, one being back to the voltage regulator.
Jeff
