News:
Did you check the fuel pump push rod like CP said? I had a very similar problem a while back and the push rod was to blame.
Is it under where the pump mounts to the engine?Thank you
under the pump you will find a small plug , after removing the pump remove the plug & the pushrod should slide out through the hole where the plug was, the pushrod is still available New from Mopar in the performance catalog
