Author Topic: Blower switch R&R  (Read 1082 times)
Offline AMXguy
Blower switch R&R
« on: June 07, 2007 - 11:04:44 AM »
 Does anyone know the best way to get at the fan switch? I need to put my new fan and A/C master controls in and I don't see any good way of getting in there. do you pull the gauge cluster or something and go in from the top?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Blower switch R&R
« Reply #1 on: June 07, 2007 - 11:07:33 AM »
4 screws & the switch panel will come out remove the end panel on the lower dash & then you can get at the heater panel , 1 screw is removed from the behind the dash near the steering column
