Author Topic: Steering column install  (Read 793 times)
Offline tumbob
« on: June 08, 2007 - 10:49:47 PM »
Ok need help with installing a steering column in a 70 challenger convert, I did not take the car apart but am putting it together, and dont now how to start, have the old column, old power steering pump in place, a new bushing kit (metal bushings, a couple of roll pins, piece of cardboard?, rubber piece, and firewall gasket).. do I need anything else? Any and all insight on installing would be awsome.
09 Challenger SE
68 Charger 383
70 Challenger Convertible 340
72 Cuda 340
Re: Steering column install
« Reply #1 on: June 11, 2007 - 03:06:00 AM »
the kit you have will rebuild the coupler , it has to have the spring to the side to locate the Shoes / blocks correctly inside the coupler , there is a small notch on the bottom lip of the coupler , it aligns with the master spline on the steering box
Offline tumbob
« Reply #2 on: June 11, 2007 - 08:16:13 PM »
CP, have the spring in the kit. amazing how all this fits together and thanks for your help. The cardboard is for? Do I grease the bushings and pack the coupler or not?
09 Challenger SE
68 Charger 383
72 Cuda 340
« Reply #3 on: June 12, 2007 - 01:14:30 AM »
there is a small pin in the coupler kit to lock the shoes into the coupler , it drives into a pin hole at the top of the coupler
pack the coupler with grease
 I have no clue what the small piece of cardboard is for or why every kit has it .... anyone else know ??
