Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Removing 8 3/4 differential ....clutch set-up
« previous
next »
Print
Pages: [
1
Author
Topic: Removing 8 3/4 differential ....clutch set-up (Read 728 times)
cuda-cable
Jr. Member
MOPAR or no car
on:
June 10, 2007 - 05:53:56 PM »
need to pull my centr section from 8 3/4 rearend.........how far out do i need to pull the axles to clear the diff to allow removal. Also i'm puting a auburn gear sure grip in.....what ype of lube goes back into the rear with this......also is there an easy way to know you have your clutch clearance correct....thx
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Removing 8 3/4 differential ....clutch set-up
Reply #1 on:
June 11, 2007 - 03:11:54 AM »
you need to pull the axles 8" out to drop the center section
I use 75-90 synthetic gear lube , you may still need the sure grip additive with the lube
Which clutch clearance ?? the Auburn doesn`t have clutches
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
