Author Topic: Plugs still white...  (Read 2447 times)
Offline 74 340 4speed
Re: Plugs still white...
« Reply #15 on: June 14, 2007 - 03:58:08 PM »
A friend of mine had a demon on his 350 and he never could get it to run right.  Several carb guys tried to tune it, but it was to no avail.  He got an edelbrock, put it on the car and drove away without even touching it.  I would recommend a holley though.  I've got them on several vehicles and have been well satisfied.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline 440Charger
« Reply #16 on: June 14, 2007 - 06:25:10 PM »
try inserting a small diameter piece of wire in to the air bleed , this will act as if you have a smaller bleed in place
I'll give that a shot.  Thanks.
I love my 440...but it's not loving me back...yet
Offline 440Charger
« Reply #17 on: June 15, 2007 - 05:13:05 PM »
Just checked three more plugs today while trying to do a compression test and found that each plug had a different shade of color.  One was very lightly tanned, one of tan, the 3rd was a light black.  Is it common to have different plug colorings?
« Reply #18 on: June 15, 2007 - 06:09:43 PM »
that sounds like an Intake leak possibly through the brake booster , which plugs are lightest?
Offline 440Charger
« Reply #19 on: June 15, 2007 - 06:35:28 PM »
The #1 was the darkest, #5 was fully tanned, and #7 was very light tan.
I just checked the hose going from the brake booster to the intake, and the intake end of the hose has a metal threaded fitting and it's tight, but the brake booster end of the hose is not clamped and I was able to squeeze it a little with my fingers so I'm guessing that could be a problem?
Offline 440Charger
« Reply #20 on: June 15, 2007 - 07:07:04 PM »
Ok I just threw on a hose clamp on the booster end and it's about as tight as I can get it.  Since it wasn't clamped it would just slide off the booster nipple easily so I'm sure that wasn't sealing.
Any idea how much air that would let into the manifold while driving?
Thanks Neil  :worshippy
Offline ShelbyDogg
« Reply #21 on: June 15, 2007 - 07:10:03 PM »
Are you out driving down the highway, then pulling over to check color?
The only time I checked my plugs was during a hard pass down the drag strip, then shutting down, coasting off, then checking them after being towed back.
Get an oxygen sensor and stop messing with your booster.
« Reply #22 on: June 15, 2007 - 07:11:08 PM »
That's probably not the problem...the gizmo that the hose goes on that plugs into the booster is called a check valve, it could be bad...do your power brakes hold vacuum?
Offline 440Charger
« Reply #23 on: June 15, 2007 - 09:35:53 PM »
I'm going to check that next, not sure right now.
FYI - clamping down the hose did make a difference and now I need to re-tune the carb, and I felt more power on the highway.
Offline 440Charger
« Reply #24 on: June 16, 2007 - 02:41:20 AM »
The vacuum is about 12
