Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Clutch Set-up for 4speed
« previous
next »
Print
Pages: [
1
Author
Topic: Clutch Set-up for 4speed (Read 816 times)
cuda-cable
Jr. Member
MOPAR or no car
on:
June 11, 2007 - 12:20:28 PM »
Is there an easy way to know if you have your clutch pedal travel set up correctly ie; should pedal engage 2" from floor or some such reference?..or do you just do it by 'feel'...thx
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Clutch Set-up for 4speed
Reply #1 on:
June 11, 2007 - 02:00:28 PM »
set it as high as possible , you need 1" play at the top of the travel , 1/2 " minimum just to keep the throw out brg from running constantly
Logged
gichy
Jr. Member
Reply #2 on:
June 12, 2007 - 11:11:19 AM »
How do you adjust this?
Is it just the rod/nut which conects to the clutch fork?
My clutch fork can be moved in and out by hand, which tells me that the bearing is not touching the pressure plate
Is this right
Logged
1974 Barracuda, 340cid, 4 speed OD !!
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
June 12, 2007 - 12:48:16 PM »
it is adjusted with the length of the threaded rod into the release fork
the release brg clips onto the fork so it could be disconnected , the fork could be wrong or the pivot inside the belhousing coul dbe mismatched to the fork
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
