Author Topic: Dash Mounted 4-Speed Reverse Light?  (Read 5636 times)
Offline PlumCrazy
Re: Dash Mounted 4-Speed Reverse Light?
« Reply #15 on: June 19, 2007 - 12:55:00 PM »
Gotcha.
At least w/the above picture(s), you have the vertical measurements and the hole diameter.  Side-to-side measurements easy; put it smack in the middle!
IIRC it is not in the middle.
Offline Carlwalski
« Reply #16 on: June 19, 2007 - 05:42:58 PM »
Do you know where exactly it is then? :clueless: You seem to know where it doesn't go is all. :1zhelp:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline PlumCrazy
« Reply #17 on: June 19, 2007 - 10:00:43 PM »
If I knew where it went I would tell you, I may be wrong, it may go in the same position as the '70, but I don't think so.  That is why I answered the way I did.  For all I care mount it in the middle of the hood.
Offline Carlwalski
« Reply #18 on: June 19, 2007 - 10:09:37 PM »
Oh OK, if you're not sure then you should make sure you make that clear. No need to get cheeky, it doesn't mean to much from a PC chair and is water off a ducks back to me. When you run the risk of ruining someones ride I think it pays to make sure you're 100% correct before you start saying "yes/no it doesn't go there".
Offline PlumCrazy
« Reply #19 on: June 19, 2007 - 10:45:03 PM »
The only pictures posted are from 1970 dashes and you were all set to drill, all I did was stop you from doing that.
I wouldn't even consider drilling a hole unless I had at least three examples of '71 dashes along with the fender tags to prove they were originals.
Offline Carlwalski
« Reply #20 on: June 19, 2007 - 10:52:15 PM »
Funny, I didn't mention anywhere I was ready with drill in hand. I saved the photos, yes but I never do anything by halves or rush into anything. I was glad you mentioned it but then you say you're not 100% if it's correct or not and could careless if I drilled it on the hood, nice. I can't see how it would be any different but will look around at photos to check. You did clearly state it was in a different position in a 71 but you had no idea where, you see my point, no dramas.
:cheers:
