Author Topic: noisy t/o bearing ?  (Read 864 times)
Offline IMNCARN82
  • LeDZeP
noisy t/o bearing ?
« on: June 12, 2007 - 06:00:06 PM »
When in neutral just idleing there is some noise,I havn't owned a manual Mopar before. Is this common?
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline AMXguy
Re: noisy t/o bearing ?
« Reply #1 on: June 12, 2007 - 06:32:41 PM »
 The first thing to check is your adjustment. the best way is to get under the car and make sure you have enough slack before engagment. just pushing the clutch pedal won't tell you much if your linkage has much wear.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #2 on: June 13, 2007 - 12:47:51 AM »
noise at idle is not right
 if the clutch is out of adjustment & the throwout brg is running all the time this would be why it has failed & is making noise , if the clutch is adjusted then possibly the input shaft brg or the counter shaft in the tranny is making noise
Offline IMNCARN82
  • LeDZeP
« Reply #3 on: June 13, 2007 - 06:06:21 AM »
We'll I must have mis-adjusted the pedal.I moved it in-line with the brake pedal.otherwise it is low.I'm going to back it off. Make sure I get the play. How low is the clutch pedal supposed to be ?  :working:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline AMXguy
« Reply #4 on: June 13, 2007 - 07:15:08 AM »
 Your clutch pedal should be a little lower than the brake, but as long as you have some free play it shouldn't matter much. like Chryco says you shouldn't  have noticable noise in your throw out anyway, but if it's not real bad and you adjust it right you might get by for some time.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline ShelbyDogg
« Reply #5 on: June 19, 2007 - 11:30:31 AM »
Look at the bearing through the inspection cover. The bearing should not be touching the clutch fingers when fully released.  The bellhousing spring should keep it pulled away if the pedal linkage isn't too tight.
