Author Topic: Choke help  (Read 546 times)
Offline 70challengerrt
Choke help
« on: June 15, 2007 - 03:41:48 PM »
I am finishing up on the 70 charger. I can not find the correct choke for the carter avs carb. I bought the on from year one (the one with the correct 45 stamped on it) and it was wrong. The local carquest can't even find the part number. The problem with the yearone choke is it dosn't fit on the well on the intake. The linkage would work. Can I remove the intake well and run it that way? Did they make diffent well to fit in the intake? My intake I believe is a 70 intake with the well that drops in.
Re: Choke help
« Reply #1 on: June 15, 2007 - 06:08:12 PM »
I believe with the choke well removed form the intake your exhaust is open
