Author Topic: Speedometer Gear Change for a 4 speed?  (Read 976 times)
Offline 74 340 4speed
« on: June 15, 2007 - 07:55:38 PM »
How do I change the speedo gear in the 4 speed in my Cuda?  I ordered the correct one from brewers performance  and I plan to change it tomorrow as well as the speedometer cable.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Re: Speedometer Gear Change for a 4 speed?
« Reply #1 on: June 15, 2007 - 10:03:46 PM »
Jack up the rear of the car , & remove the housing with the forked clamp holding it in place , you will probably satill need a drain pan to catch fluid , install new gear & reinsert housing making SURE it is clocked / rotated to align properly , reinstall lost fluid
« Reply #2 on: June 15, 2007 - 10:21:44 PM »
Chryco, thanks for the advice but I don't understand  what the "forked clamp" is. Is this some sort of clamp that holds the speedometer gear inside the tailshaft?
Andy
« Reply #3 on: June 16, 2007 - 08:29:33 AM »
yea "forked clamp"...looks & works kindof like a distributor hold down clamp.
« Reply #4 on: June 17, 2007 - 12:17:07 PM »
Yep, just one bolt holding it in place. It "forks" over the housing for the speedo gear.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #5 on: June 17, 2007 - 01:51:05 PM »
I just change mine recently.  It is real easy, just make sure you have it indexed correctly.   :2thumbs:
« Reply #6 on: June 22, 2007 - 09:42:07 PM »
I got it in today.  Yay for an accurate speedo!  3,000 rpm at 55mph.  :lol:
Andy
