After a lot of troubleshooting, JAZ sent me a replacement sending unit, and unfortunately it performs the exact same way as the one that came in my 12 gallon fuel cell. I've made sure everything is hooked up right and grounded properly. I measured ohms per inch of magnate travel in each sending unit, and I hooked up each unit to my fuel gauge. My fuel cell is 10 inches high, and with the sending unit float magnet at 5 inches above the botton of the cell, my autoguage fuel gauge reads at the top of the "E". It should be reading 1/2 full. At 7 inches above the bottom of the fuel cell the guage reads 1/4 full, instead of almost 3/4 full. There is not the accuracy to tell when I might run out of fuel. JAZ insists that the sending unit is working as designed, while I insist that it is a poor design. One design problem is the sending unit float magnate bottom position is 2 inches from the floor of the cell, and the highest position is about 1 and 1/4 inch from top of cell. In my opinion, it is a poor application of a poor design. Maybe the signal strenth from the JAZ sending unit is too weak, even though the resistance is correct. Maybe the unit needs a stronger magnet? JAZ has been kind enough to give me a $75 dollar refund on my $210 purchase price. I will look for a more accurate guage, or try to make one myself. In the mean time, I will get some rubber and aluminum plate and plug the hole in the top of the cell. As I mentioned earlier, my autoguage fuel guage is a Chrysler 70 - 10 ohm, and worked great with a newer sending unit that was in my gas tank.
